1997 Ford Escort starter
110,000 MILES • 4 CYL • FWD • AUTOMATIC
NORM51
Sometimes i have to hold the key in the srart position for a minute, on other occasions 2 and maybe 3 minutes before it cranks up. Most of the times she'll crank up with no delay.
Apr 10, 2010 at 7:58 AM
  • 75,988 POSTS
Hi norm51, Welcome to 2carpros and TY for the donation
Double check battery condition and connections if okay-start by doing a starter current draw test, test the starter relay, transmission range switch and ignition switch.
Apr 10, 2010 at 8:06 AM
NORM51
[quote:342dc52833="rasmataz"]Hi norm51, Welcome to 2carpros and TY for the donation
Double check battery condition and connections if okay-start by doing a starter current draw test, test the starter relay, transmission range switch and ignition switch.[/quote:342dc52833] Where's the starter relay & trans range switch. thanks.
Apr 10, 2010 at 8:19 AM
  • 75,988 POSTS
Disregard the starter relay and check the inhibitor relay behind left side of instrument panel and transmission range sensoe/ switch is at the left side of engine on top of transmission
https://images.2carpros.com/forum/automotive_pictures/12900_s1_44.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_s2_41.jpg
Apr 10, 2010 at 9:17 AM
