1997 Ford Escort stalling when at stops
143,000 MILES • 4 CYL • FWD • AUTOMATIC
SHIMMY
when I stop at a red light or stop sign it was hesitating now its stalling unless I put it in neutral and give it gas .Tonight I pulled up and had to come to a complete stop and it stalled before I even got in neutral to give it gas. pulled up in front of home and left off gas to pull in and it almost stalled til I tapped the gas a little.I put it in park and gave it some gas , left it come back to normal idle and it stalled.Basically I have to use 2 feet to keep it going without stalling. As long as I'm driving its ok
Aug 6, 2008 at 3:07 PM
BMRFIXIT
  • 19,053 POSTS
check throttle body and clean
check for any vacuum leak
clean and or replace idle air control valve
Aug 7, 2008 at 2:55 PM
