1997 Ford Escort Shifts hard
1997 FORD ESCORT
65,000 MILES • 4 CYL • FWD • AUTOMATIC
SCOTT RICKABAUGH
Purchased at 65,000, 10 miles away from dealer started dropping neutral, pulled stick, clear fluid(looked like pw steer fluid), dealer replaces trannie, but now shifts hard, I have to let off just before the shift for it to transition smoothly, all gears, decreasing slightly as I progress through the gears. THANX
Jul 29, 2010 at 5:16 AM
  • 110,240 POSTS
Is the engine reving high before shifting?
Jul 29, 2010 at 5:07 PM
SCOTT RICKABAUGH
Yes, alittle more than it should.
Aug 2, 2010 at 11:46 PM
  • 110,240 POSTS
With that in mind, I would recommend having the shift solenoids checked. That sounds like where the problem is coming from.
Aug 3, 2010 at 4:39 AM
