1997 Ford Escort Sheet metal type rubbing
1997 FORD ESCORT
189,000 MILES • 4 CYL • FWD • MANUAL
KNB1353
About a month ago the car developed a sheet metal sounding rubbing noise coming from the right front of the car. As opposed to a metal grinding, like a brake disc. The noise happens when a left turn is made or there is a passenger in the front right seat. It goes away when accelerating and comes back when cruise speed has been reached or gas pedal is released. Right wheel bearing has been changed, tires and wheels have been rotated, brake caliper shielding has been removed and inspected and reinstalled.
Jan 21, 2009 at 2:26 PM
BILLYMAC
  • 2,204 POSTS
hi kn. you should check your ball joints immediately. very dangerous they can break and you have hardly any steering.if the ball joints are ok then check the backing plate behind the rotor these get bent from ice and snow .if this is the prob you will see a shiny spot where it has rubbed. if none of these then a hub bearing is going bad. good luck billymac
Jan 24, 2009 at 6:56 AM
