1997 Ford Escort Please Help!
136,000 MILES • 4 CYL • FWD • AUTOMATIC
GOKU98665
  • 5 POSTS
My car has been making a clicking noise for about a week. Today I started and it miss fired. Turned it off started again no problem. It does it, off and on. I checked the check engine code. P0304 number 4 cylinder miss fire. I change the fuel filter, spark plugs, and wires wires. Did a compression test. checked the lifters, and tested for vac leaks, and clean all components to do with air. I'm kinda leaning twards a bag injector. Any thoughts?
May 23, 2009 at 9:59 AM
  • 75,988 POSTS
Sparkplug and compression for that cyl okay-You could be on the right track with the injector
Engine Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
May 23, 2009 at 10:33 AM
