Going though alot of oil, only see leaking around valve cover. Car will run and go for about 1 mile, then it stops and stays running, but won't go? Then if you turn if off and wait for 15 mins and turn it on, it will go for another mile and stop again??? Is there a sensor that could be causing this, or does this sound like a transmission problem. Any ideas would be helpful. PS NO oil on ground or oil burning signs.
Mar 14, 2009 at 4:09 AM
