The number 2 and 4 cylinders are misfiring on my split port fule injection 2000. It ran fine after I changed the spark plug and wires. Then two days later the #2 cylinders were misfiring with no pick up on the hills. I changed the spark plugs and the wires and fuil filter. Then I was told to change the three prong electrical wire harness (pig tail)plugged into the coil (This may or may not help). Not the coil itself. I have not done a compression test yet. What else should I check out?
Mar 3, 2010 at 12:34 PM
