1997 Ford Escort MASS AIR SENSOR FAULT
1997 FORD ESCORT
78,000 MILES • 4 CYL • FWD • MANUAL
VICKI112
HI I have been to my mechanic and had my computer scanned for fault and it said faulty mass air sensor replaced it with new one and it still reads the same. The problems i am having are rough idle ,cutting out while braking,and cutting out when in first gear waiting at lights what can it be please any ideas? my mechanic is getting a new mass air sensor in case this one is faulty but if not then im stumped!
Feb 23, 2009 at 10:32 PM
BMRFIXIT
  • 19,053 POSTS
Defective sensor is possible
check wiring
if you can get me the code will be able to help more
(P0000)
Feb 23, 2009 at 10:47 PM
VICKI112
hi sorry havent got the code from the computer but the mechanic is getting a new sensor to see if that works on friday thanks
Feb 23, 2009 at 10:50 PM
VICKI112
Well you were right about it being a faulty sensor thank you it worked fine for 10 days was a dream to drive and then.... started her up and she wont hold idle as soon as i lift off the gas pedal she dies on me. To start her up i need to press the gas pedal also otherwise she just doesnt turn over any ideas guys thank you
vicki
Mar 10, 2009 at 11:01 AM
BMRFIXIT
  • 19,053 POSTS
Sounds as idle air control
check it clean it and also check for any vacuum leaks
replace idle air control valve
Mar 10, 2009 at 11:42 AM
