IGNITION COIL
SHEENIE10
Engine Mechanical problem
1997 Ford Escort 4 cyl Automatic
Im replacing an ignition coil and i was just wanting to see video on it so that way when i put it back together i put the spark plug wires back to it correct place?
Sep 8, 2009 at 12:25 PM
BMRFIXIT
  • 19,053 POSTS
Here is the firing order and a video of the job being done on a 6 cylinder ford. Almost the same thing https://youtu.be/iDgXwKA-IIc
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_494.jpg
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Sep 8, 2009 at 11:09 PM
