1997 Ford Escort I need some Information????
144,000 MILES • 4 CYL • FWD • MANUAL
JSKIDMO5
  • 6 POSTS
I have a ford escort and the fan inside will not work on the highest setting but it will strangely work on the first three settings. I have replaced the small fuse at the pig-tail but that didn't fix my problem. What should I do and How can I get what I need.
Sep 1, 2009 at 1:43 AM
RACEFAN966
  • 5,029 POSTS
OK with the blower motor not working on only one speed then I would say check or replace the blower motor resistor. Here is a pic. This resistor controls the speeds.
https://images.2carpros.com/forum/automotive_pictures/249564_819129_1.jpg
Sep 1, 2009 at 3:55 AM
JSKIDMO5
  • 6 POSTS
[quote="racefan966"]OK with the blower motor not working on only one speed then I would say check or replace the blower motor resistor. Here is a pic. This resistor controls the speeds.
I don't know where that is located. I have replaced a smaller resister but I don't think this is the same thing. So I am not sure exactly what that is and where I can get one.
Sep 2, 2009 at 2:43 AM
RACEFAN966
  • 5,029 POSTS
OK the blower motor resistor will be on the heater/ac box not far from the blower motor. The pic I included is the exact one you should have so it should look just like it.
Sep 2, 2009 at 3:31 AM
