How to replace a radiator cooling fan relay
131,000 MILES • 4 CYL • FWD • MANUAL
RAY_VALENCIA
I have bougth the relay already, now I would like to know where is the location of this part in the car so I can change it myself thanks for your help
Oct 28, 2008 at 11:02 AM
BMRFIXIT
  • 19,053 POSTS
You do not have a relay just for the coolant fan motor
what you have is a constant control relay module (CCRM)
located left front of engine behind left headlight it controls PCM, fuel pump and so on
Jun 6, 2020 at 5:46 AM
RAY_VALENCIA
Thanks for the answer, What happens is that the cooling fan is running all times even the engine is off, and i have to take the fuse out to dont run out of battery, and the mechanic told me that is the piece i need...... In case is that the piece i need can You give some clues how to install this relay
thanks for you help
BMRFIXIT
  • 19,053 POSTS
Do you have check engine light on? Get the codes will help if u do once you locate the CCRM its simple to replace wire plug is secured on the module with a bolt.
