HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Climate Control
Heater
Heater Core
SPONSORED LINKS
1997 Ford Escort Heater
JANISITTAUTO
MEMBER
1997 FORD ESCORT
4 CYL
FWD
AUTOMATIC
68,000 MILES
I am pretty sure I need the heater core. It has been bypassed. Do you have to remove the dashboard to install the heater core? How long does it take?
Thanks!
Tuesday, November 4th, 2008 AT 9:03 PM
BMRFIXIT
MECHANIC
To do the heater core all must come out dashboard and instrument panel to get to the HVAC box and remove
its about 7 hours to do
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Wednesday, November 5th, 2008 AT 7:52 PM
Please
login
or
register
to post a reply.
Related Heater Heater Core Content
1997 Ford Escort
My Heater Core Has Been Replaced Twice Within The Past Year And A Half My Heat Or Air Conditioning Is Working And My Fan Runs The Whole Time...
Asked by
hattiek32
1997
FORD ESCORT
GUIDE
Heater Core Replacement
A heater core is positioned inside the car and is part of the HVAC system. Hot engine coolant is run through the core which air is blown through via the blower motor which ...
1997 Ford Escort
Heater Problem 1997 Ford Escort 4 Cyl Four Wheel Drive Automatic How To Change Heater Core For Replacement
Asked by
siullegna
1 ANSWER
1997
FORD ESCORT
Ford Escort 1986 Heater Core
How Do I Remove The Heater Core On A 1986 Ford Escort With Ac? It Has The Core With One Pipe Over The Other. I Have Spent Quite A Bit Of...
Asked by
jerryc41
1 ANSWER
1986
FORD ESCORT
Heater Core
Ok I Did All That You Said But The Frame For The Instrumental Panel Is In The Way So I Can't Get To Pull Out The Black Casing That Contains...
Asked by
trini1962
1 ANSWER
1993
FORD ESCORT
1994 Ford Escort Heater Core 94 Escort
My 94 Escort Was Leaking Radiator Coolant Into The Driver And Passanger Side Floorboard. I Was Told That It Is The Heater Core. I Took The...
Asked by
BigJaime
1 ANSWER
1994
FORD ESCORT
VIEW MORE
SPONSORED LINKS
Heater Hose Replacement Chevrolet Camaro
Coolant Leak Symptoms
Online car repair manuals
