1997 Ford Escort Gears won't engage
120,000 MILES • 4 CYL • FWD • AUTOMATIC
SANDWICH78
The engine starts and runs fine, but when I move the gear shift to R,D,L nothing happens. Should I try to change out the fluid or just tow it to a transmission shop?
Jul 28, 2009 at 3:17 AM
LAZYGAZER
  • 68 POSTS
First check to see if there is oil by checking the t/m dipstick while the engine is running in park. If there is oil to the full mark then the tranny is needing professional attention. If there is little or no oil add and see what happens which by now the clutches are probably burnt due to lack of oil. If nothing happens see a professional t/m repair shop.
Jul 30, 2009 at 1:21 PM
