1997 Ford Escort Fuel injection
1997 FORD ESCORT
RICK67005
1997 Ford Escort 4 cyl Two Wheel Drive Automatic
Changed out the fuel and the car ran for about 20 minutes. change out the fuel pressure regulator and the ran for about 15 minutes. before I changed the fuel pressure regulator I connected a fuel pressure test gauge to fuel rail and I had zero pressure. After changing the fuel pressure regulator I had zero fel pressure but the car ran. what could be the problem?
Nov 9, 2008 at 5:23 PM
BMRFIXIT
  • 19,053 POSTS
suspect bad fuel pump
Nov 9, 2008 at 6:59 PM
