1997 Escort wagon 2.0 L. Automatic. I was driving on the highway no problem. Got into some slower traffic and at the light felt a miss in the engine. After the light changed it seemed like there wasn't as much power as before. Next stop I put the car in neutral had a miss but stayed running ,brought up the RPM a bit and engine ran smoothe. Next light I stopped , let the car idle and it died. Tried to start, it fired a couple times and didn't fire anymore. Towed home pulled the timing belt cover, belt did not turn. Teeth missing on belt at crank pulley. Replaced belt, set timing marks , still won't start, have fuel, have pressure , coil tests (multimeter) okay, but will not fire. will check compression next.No fault codes either. HELP !
Jun 13, 2008 at 4:26 AM
