1997 Ford Escort engine coolant
130,000 MILES • 4 CYL • FWD • AUTOMATIC
LJF
  • 14 POSTS
I drained the radiator today to replace the coolant
and all I got out was about a quart and a half of liquid
from the valve at the bottom of the radiator. I assume this means I have to find the engine block valve to let water out of the block. Is there one and if so,where is it located .Thanks for the reply.
Feb 6, 2008 at 6:35 AM
BMRFIXIT
  • 19,053 POSTS
[quote:1f116abee7="ljf"]Other Category problem
1997 Ford Escort 4 cyl Front Wheel Drive Automatic 130000 miles
from the valve at the bottom of the radiator. I assume this means I have to find the engine block valve to let water out of the block. Is there one and if so,where is it located .Thanks for the reply.[/quote:1f116abee7]
Easy and quick way remove lower radiator hose
Feb 6, 2008 at 10:55 AM
