1997 Ford Escort door lock
182,000 MILES • 4 CYL • FWD • AUTOMATIC
STARCRAFTT
  • 6 POSTS
the passenger side door lock wont work. is this easy to fix? how much would it cost to fix at a shop? or can i do it cheaper ?would i get the same lock, because the key i have does everything . or iam i going to have another lock with another key just for that door
Apr 25, 2010 at 3:21 PM
  • 110,251 POSTS
Are you refering to manual door locks or electric?
May 6, 2010 at 5:19 AM
STARCRAFTT
  • 6 POSTS
it is a manual lock
May 6, 2010 at 5:19 PM
  • 110,251 POSTS
What I recommend is removing the door panel and taking a look inside. Chances are the linkage has come off or broken. You should be able to do it yourself. The only hard part is that it is tight to work on.
May 6, 2010 at 11:38 PM
STARCRAFTT
  • 6 POSTS
thanks very much for the advice
May 7, 2010 at 5:50 PM
  • 110,251 POSTS
May 8, 2010 at 1:04 PM
STARCRAFTT
  • 6 POSTS
the linkage came off needle nose pliers and glue weld. hope it holds
May 9, 2010 at 11:23 AM
  • 110,251 POSTS
Glad you found it. That is usually what happens. I'll keep my fingers crossed for you.
Take care and let us know if you have questions in the future.
May 9, 2010 at 11:36 PM
