1997 Ford Escort choke problem
66,424 MILES • 4 CYL • FWD • MANUAL
WIDEWHEELS
automatic choke get stuck on, sometime's dies completely.
What is the term ECM?
Feb 7, 2009 at 12:55 PM
OBXAUTOMEDIC
  • 3,715 POSTS
[quote:3eb3c135b3="widewheels"]Engine Performance problem
1997 Ford Escort 4 cyl Front Wheel Drive Manual 66424 miles
What is the term ECM?[/quote:3eb3c135b3]
Can you describe the problem exactly. Fuel injected vehicle have a throttle body and a butterfly Vavle it is not called a choke anymore.
Also, is your check engine like on if so would you be able to drive it to your local auto parts store to have them pull codes. If so post codes here.
The ECM is you Electronic Control Module.
If your Idle is high it could be caused by the IAC (Idle Air Control) Valve. It could just need to be cleaned. Or it could be your TPS (Throttle Position Sensor).
Getting the codes read would help identify the posible problem.
Feb 7, 2009 at 1:07 PM
