1997 Ford Escort car shimmying when on highway, over 50-55mp
1997 FORD ESCORT
125,000 MILES • 4 CYL • FWD • AUTOMATIC
LINDAJESSIE
  • 16 POSTS
1997 ford escort , car shimmying on highway, just had right front whell/hub bearing replaced, what else could be causing the shimmying, it's a slight side to side motion at high speeds. Thanks in advance for any help
Dec 6, 2007 at 8:21 AM
BMRFIXIT
  • 19,053 POSTS
[quote:aec3e16030="lindajessie"]Steering problem
1997 Ford Escort 4 cyl Front Wheel Drive Automatic 125000 miles
1997 ford escort , car shimmying on highway, just had right front whell/hub bearing replaced, what else could be causing the shimmying, it's a slight side to side motion at high speeds. Thanks in advance for any help[/quote:aec3e16030]
Check tires may be rotate them also have them balanced
Check alignment
Good luck
Dec 6, 2007 at 8:26 AM
