1997 Ford Escort 97 Ford Escort Ignition Clicks, Fails, Cli
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
5TEIN
I have had a 1997 Ford Escort for a number of years. I've had a minor problem for the past two years that is now getting to be annoying:
Every once in a while--completely inconsistently--the car won't start straight away.
I turn the key, it clicks, everything has power. I turn again, click. About 4 turns later, the locks go down and up, the alarm chirps, and then it will start.
Recently this has taken as many as 15 turns!
Battery is new, starter is relatively new, battery wires look OK at a glance but I haven't investigated those fully.
Oct 30, 2008 at 3:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Have you had the alternator tested?
Oct 30, 2008 at 6:32 PM
5TEIN
Yes, in fact it was replaced about a year ago. I don't know why I forgot to mention that.
Oct 31, 2008 at 3:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Your ignition switch could be going bad. Your key will turn but it will act as if the starter is out. If you have some knowledge with starters and mechanics you can wire up a push button starter switch to the starter (just temporarily) to see if it starts up first time. If you don't feel comfortable doing this than you can have your local garage take a look at the ignition switch and see if it is faulty.
Oct 31, 2008 at 5:21 AM
