1997 Ford Escort 2nd gear grinding, can't get it in sometim
1997 FORD ESCORT
63,000 MILES • 4 CYL • FWD • MANUAL
MATTBPE
On occasion, I can't shift into 2nd gear (up or downshifting). Get some grinding. All other gears work fine. 4th acted up once, but 2nd gear seems to be the problem. It doesn't do it all the time either. Could this be a bad clutch? Master cylinder and slave cylinder have been replaced.
Sep 4, 2009 at 8:17 AM
Try bleeding it out don't work might need a new clutch assy.
Sep 4, 2009 at 8:21 AM
