1997 Ford Escort #2 cylinder code
122,000 MILES • 4 CYL • 2WD • AUTOMATIC
DANO322
I recently pulled a p0302 code(#2 cyl. misfire) and noticed a lot of smoke from the tailpipe and a possible misfire at initial start up. Plug had minor residue on it, but nothing seemingly serious. Replaced the valve stem seals under valve cover. In doing so, I found an air leak in cylinders #2 and# 3.A compression test yielded #1 and #4 at 160lbs. and #2 and #3 at 85lbs. Is this a head gasket or am I looking at a more serious internal engine problem?
Aug 22, 2010 at 3:34 PM
  • 75,988 POSTS
Low compression on adjacent cylinders-points to a blown headgasket
Aug 22, 2010 at 5:38 PM
