1997 Ford Escort
1997 FORD ESCORT
THEWRECKLESS
Engine Mechanical problem
1997 Ford Escort 4 cyl Two Wheel Drive Automatic
how come the belt makes a sqeaking noise, n the belt dosent need tightend
Sep 16, 2010 at 6:28 PM
DSPLC
  • CAR REPAIR CONTRIBUTOR
  • 220 POSTS
Maybe your car needs a new belt tensioner and idler pulley. Or the serpentine belt itself. Also, do not use Goodyear gatorback serpentine belt, makes a humming noise. Picture below is the tensioner. It has a spring inside that tightens the belt automatically. Maybe the spring is getting soft and could not tighten the belt well.
https://images.2carpros.com/forum/automotive_pictures/89255_belt_tensioner_1.jpg
Below is the idler pulley. If your car got too many miles, bearing inside tends to wear out.
https://images.2carpros.com/forum/automotive_pictures/89255_idler_pulley_1.jpg
Sep 17, 2010 at 12:12 AM
