1997 Ford Escort
THOMAS BOYER
Noises problem
1997 Ford Escort 4 cyl Automatic
WHEN ATTEMPTING TO START CAR, ENGINE MAKES A GRINDING NOISE AND TAKES SEVERAL TIMES BEFORE TURNING OVER. ENGINE WILL ONLY RUN FOR ABOUT 10 SECONDS BEFORE SHUTTING DOWN, ALSO WITHIN THOSE FEW SECONDS ENGINE RUNS VERY ROUGH.
Sep 11, 2010 at 6:33 AM
  • 75,988 POSTS
Hi THOMAS BOYER, Welcome to 2carpros and TY for the donation this is what keeps the site going to help people in need and to cut costs-
Lets start by inspecting the conditions of the starter motor drive pinion and the flexplate ring gear.
Dying out in 10secs with rough/erractic idle -check the fuel pressure if its wiithin specs if normal try cleaning out the idle air control valve and EGR/PCV valves and clean the mAF sneor with an electronic cleaner CRC and test the throttle position sensor-
Dec 14, 2018 at 1:39 AM
