1997 Ford Escort
81,000 MILES • 4 CYL • FWD • AUTOMATIC
TOOFLACA
i hear a ticking noise from the passenger side. i've replaced the u spring on the front right caliper and it stopped for a few days and now it's back but the spring is still good
Aug 1, 2010 at 3:45 PM
  • 110,246 POSTS
Does it happen all the time or just when turning? Also, does it change with the vehicle speed?
Aug 1, 2010 at 4:59 PM
TOOFLACA
it gets louder the faster i go. i don't think it is the cv boot because it doesn't make that clunking noise when i turn. should i check the rear brakes or do i not have any?
Aug 2, 2010 at 12:29 PM
  • 110,246 POSTS
If it stopped when you replaced the brake parts and is making the same noise again, check to make sure everything is tight including the calipers.
Aug 2, 2010 at 6:10 PM
TOOFLACA
will do. thank you. if the problem persists i will contact you again. great services, i am recommending this site to friends and family.
Aug 3, 2010 at 1:40 PM
  • 110,246 POSTS
You're welcome. Let me know what you find. And thanks for recommending us. Tell as many people as you can.
Aug 3, 2010 at 5:12 PM
