1997 Ford Escort Front Wheel Drive Automatic 142000 miles
my car got stuck in about knee high mud and i turned it off to save the battery.my friend pulled me out and it seemed fine comepletely covered it mud but ok.well i tried to start it but it wouldnt, they key would turn but it just wouldnt run. i went to a car wash and pressure washed everything, i couldnt get to the air fillter timing belt or the engine cause of the covering on it but i got a wrecker to bring it home, ive talked to a couple people and a few said id just need to clean out the engine timing belt and everything else and itd be alright others said i needed to check the timing belt wash it and probably replace it, or the air filter off so i could spray a goot amount of starter fluid in it and if that didnt work it would be an electrical problem. any ideas?
Mar 17, 2010 at 9:35 AM
