1997 Ford Escort
175,000 MILES • 4 CYL • 2WD • AUTOMATIC
DDHOEY
How do I change my car's instrument cluster light bulbs - all are out -thanks.
Feb 10, 2009 at 3:37 AM
BOWTIE BABY
  • 101 POSTS
If all of your dash lights went out at the same time, check the fuses 1st. To replace the dash bulbs you will have to remove the cluster from the dash, Its easier than it looks. Remove the plastic trim to access the srews for the cluster. Remove the cluster screws and slowly remove, you need to unplug the wiring harness and speedometer cable if it has 1. Then twist black light sockets a quarter turn counter clockwise and pull out. replace bulbs and reassemble.
Feb 10, 2009 at 9:26 AM
DDHOEY
you for your speedy response to my question! My problem is that I do not know how to remove the lower plastic panel directly under the gauges - I can't find the clips or fasteners.
Feb 10, 2009 at 10:24 AM
DAVE H
  • 13,383 POSTS
INSTRUMENT CLUSTER
Removal & Installation
Disconnect negative battery cable. Remove nut on back side of hood latch pull handle and remove handle. Remove screw from instrument panel steering column cover and panel and remove cover and panel. Remove 5 screws and instrument panel upper finish panel. Remove 4 instrument cluster mounting screws. Pull instrument cluster out and disconnect 3 electrical connectors. Remove instrument cluster. To install, reverse removal procedure.
Feb 10, 2009 at 10:41 AM
BOWTIE BABY
  • 101 POSTS
No problem. Dave H knows what hes talking about, Follow his directions and you shouldnt have any problems. Good Luck, Please give feedback. Let me know if you have any other questions.
Feb 10, 2009 at 10:50 AM
