1996 Ford Escort strutts
SUPERJOKER
Suspension problem
1996 Ford Escort 4 cyl Front Wheel Drive Manual
i need to replace the strutts in a 1996 ford escort wagon. what kind of tools and such do i need to do the job
Oct 17, 2009 at 4:13 AM
  • 110,248 POSTS
THe necessary tools are straight forward. However, you will need a coil spring compressor. Most parts stores will lend or rent them to you.
Please be careful and follow the directions that come with the tool. A coil spring could kill you if it gets loose and hits you.
Also, the vehicle should be aligned after the job is done.
Oct 19, 2009 at 2:18 PM
