Engine Performance problem
1996 Ford Escort 4 cyl Two Wheel Drive Manual
Hiya I have a escort 1800cc zetec and when i first start the car mornings or after being left for 5 hours or so the car tends to stall 3 or 4 times. After the 4th time it will run fine apart from the revs will drop down occasionally and sometimes rev about 1500 then drops down to normal. I have changed the plugs, leads, air flow sensor, lamba sensor and clean the switchs with electrical cleaner. This has helped the running of the car but not the stalling problem. If you have any advice to give me to sort this problem i would be very grateful.
Many thanks
Lee
Many thanks
Lee
Aug 13, 2008 at 1:00 AM
