1996 Ford Escort POWER STEERING PUMP
1996 FORD ESCORT
MADMIKED
Steering problem
1996 Ford Escort Manual
THE POWER STEERING PUMP LEAKS, HOW DO I FIND THE ORIGIN OF THE LEAK.
May 10, 2008 at 7:03 PM
MASTERTECHTIM
  • 4,750 POSTS
start by thoroughly cleaning the area then run the car and watch for the fluid leaking out. if its the pump, dont try to fix it, just install a new one.
May 10, 2008 at 11:05 PM
MADMIKED
THANK YOU FOR YOUR REPLY. THE VEHICLE HAS BEEN STATIONARY FOR A WEEK AND PUMP LEAKS MORE NOW THAN IT DID DURING TRANSIT(?). WILL TRY YOUR ADVICE. THE VEHICLE WAS REPAIRED (FIRST BURST RADIATOR & THEN BROKEN WATER PUMP) - PUMP WAS CLEAN WHEN IT WENT IN, IT CAME BACK FILTHY FROM THE MECHANIC.
May 11, 2008 at 1:45 AM
