Hi to check if your pump is working there is 2 options 1st as you turn on your ignition you should hear the pump building pressure then shuts off if not its not energizing. 2nd the fuel rail has a valve for a pressure guage you could gently push the valve in and see if fuel comes out an if it is under pressure when it does.
Your donation is appreciated.
SPONSORED LINKS
Friday, December 14th, 2018 AT 9:42 AM
