1996 Ford Escort idle problem
130,000 MILES • 4 CYL • FWD • MANUAL
ICHABOD
plain jane ford escort starts ok, but idles down to rough / stumble idle. compression check ok, no bad valves per vacuum guage. replaced idle air control valve, no help. vacuum guage swings wide when idling - looking at timing problem ? if so-why and what part ?
Oct 20, 2008 at 11:16 AM
  • 75,988 POSTS
Is this how your vac gauge look like
https://images.2carpros.com/forum/automotive_pictures/12900_vac15_1.gif
Check the PCV/EGR valves and throttle position/MAF sensors
Oct 20, 2008 at 11:24 AM
