HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Ignition
Timing
1996 Ford Escort How to set timing
NENESNATURE
MEMBER
1996 FORD ESCORT
4 CYL
FWD
AUTOMATIC
14,000 MILES
We reworked the heads and now am having trouble setting the timing correctly, can you please help me?
Monday, November 24th, 2008 AT 3:35 PM
MECHANIC
Put engine no.1 piston up on its compression stroke and align sprockets -see below
Monday, November 24th, 2008 AT 3:44 PM
Please
login
or
register
to post a reply.
Related Ignition Timing Content
1996 Ford Escort Timing
Can You Please Describe The Process For Changing The Timing Belt? I Need To Know Where To Place The Point On The Crank And The Cam Shft. ...
Asked by
blackjl55
1 ANSWER
1996
FORD ESCORT
1992 Ford Escort Timing
Engine Mechanical Problem 1992 Ford Escort 6 Cyl Front Wheel Drive Manual I Got The Timing Belt On (replaced) Without Getting The...
Asked by
bclarin2008
1992
FORD ESCORT
Timing
How To Adjust The Timing?
Asked by
ericconkin
1999
FORD ESCORT
Common Issues That Cause The Timing To Jump?
1998 Ford Escort Sport 96k Milles 2.0l Sohc. Two Different Times Now My Car Has Jumped Timing. The Timing Belt, Tensioner And Water Pump...
Asked by
babsydawl
FORD ESCORT
Timing
I Just Replaced My Timing Belt And Trying To Start, But It Will Not Turn Over. I Give It Gas And It Almost Starts. Both Points Line Up...
Asked by
Stevenmote
1998
FORD ESCORT
VIEW MORE
Fix an Engine with Low Power!
Symptoms of Low Engine Power
Low Engine Power
