Heater problem
1996 Ford Escort 4 cyl Front Wheel Drive Manual
on ocasion the fan will not run seems to be worse when cold out
Friday, January 16th, 2009 AT 10:05 AM
MECHANIC
Hi:
What you need to do is check to see if it's getting power when it isn't working. It could be a ground problem or the motor may be going bad. Let me know what you find.
