1996 Ford Escort Heater Core
190,000 MILES • 4 CYL • FWD • AUTOMATIC
JSIPPEL
I just paid over 500 dollars to have my heater core replaced in my car. I had all the usual symptoms including the white smoke, the smell, the wet front seat floor, and the overheating engine. After having the car back for one day, I noticed the smell again and sure enough the carpet was wet in the same spot. My question is whether there is an underlying problem that is causing the heater core to blow or was it a faulty part or a mistake on behalf of the mechanic? I just want to know if this will continue to occur and if I should cut my loses now by junking the car?
Jul 5, 2008 at 5:17 PM
BMRFIXIT
  • 19,053 POSTS
I would give the mechanic the chance to check it and tell you what is going on
white smoke out the exhaust usually an indication of a headgasket failure
good luck
Jul 6, 2008 at 12:56 AM
