1996 Ford Escort EVAP Canister Control Valve
TONYTIGER32
  • 1996 FORD ESCORT
  • 4 CYL
  • 166,240 MILES
I have replaced my EVAP Purge Valve and all the parts on the EGR SYstem. And the code keeps coming up for the EVAP Purge Valve and the EVAP Monitor isn't coming online. I have everyrthing hooked up properly, I am wondering if my gas cap is no good since it is the OEM Cap, or is my canister itself bad. I first was having a problem with my EGR system where the code EGR Insufficient Flow code kept appearing, so I changed the EGR Valve, The Pressure Sensor, and The EVC. But I am thinking if I don't have a tight enough connection on the pressure sensor, would that relate to the EVAP system? Or would the intake port for The EVAP Purge valve on The Throttle Body be gummed up bwith alot of carbon deposits? I am almost pulling my hair out with this EVAP problem so I need some help here okay guys?
http://www.2carpros.com/forum/automotive_pictures/253653_0425081132a1_1.jpg
Thursday, October 9th, 2008 AT 3:29 PM
BMRFIXIT
  • 19,053 POSTS
What is the code #
Saturday, October 11th, 2008 AT 6:18 AM
TONYTIGER32
  • 5 POSTS
The code is P1443 which I did research on and it relates to the Purge Valve
Monday, October 13th, 2008 AT 3:27 PM
BMRFIXIT
  • 19,053 POSTS
Check connector at solenoid and also check the wiring
Monday, October 13th, 2008 AT 6:41 PM
