1996 Ford Escort engine cooling fan
GREGCAMERON
Engine Cooling problem
1996 Ford Escort 4 cyl Front Wheel Drive Automatic
engine cooling fan wont come on. I have hard wired a toogle switch for now. Replaced fan motor, relays fuses. Any idea on what is next or what generally goes wrong?
Nov 18, 2008 at 10:48 PM
DAVE H
  • 13,383 POSTS
COOLING FAN
The cooling fan (and high speed cooling fan on A/T) is controlled by conventional fan coolant temperature switch(es) and relay. The PCM controls cooling fan during A/C operation.
Engine coolant Temperature switch ..on left front of engine
Nov 18, 2008 at 11:56 PM
GREGCAMERON
ALAS, I have found the problem!!! I found the main hot wire which controls the fan was corroded and broken on the bottom side of the fuse box under the hood!!
Jan 23, 2009 at 11:30 PM
DAVE H
  • 13,383 POSTS
Thanks for the update .. this may help others in the future !!
Happy motoring
Dave H
Jan 23, 2009 at 11:54 PM
