1996 Ford Escort Cooling fan is not working
MULLISM
Electrical problem
1996 Ford Escort 4 cyl 104000 miles
My cooling fan stopped working. I can run a hot wire to terminals on plug and fan works. I have 12. volts on the fuse and the fuse is not blown. What do I need to look for next?Where would the relays be located?
May 4, 2010 at 12:15 AM
  • 110,248 POSTS
It could be a relay or a bad temp sensor. Check the relay first.
May 6, 2010 at 4:46 AM
