1996 Ford Escort Coolant Leak
202,000 MILES • 4 CYL • 2WD • AUTOMATIC
PHIA
I have 96 Ford Escort 1.9L and its leaking antifreeze when the car is running the leak stops and/or slows down but when I turn it off the leak is pretty bad not quite sure where the leak is coming from seems to be coming from around the antifreeze resivior tank
Mar 20, 2008 at 10:06 AM
SERVICE WRITER
  • 9,123 POSTS
You need to get in closer and look. Use good lighting and mirrors if needed. A digital camera can be a help as well for areas you can't see well. Pics can be posted here also.
Mar 20, 2008 at 11:09 AM
