1996 Ford Escort check engine light
NENLUV
  • 1996 FORD ESCORT
Electrical problem
1996 Ford Escort Front Wheel Drive Manual
i just replaced my check engine light on my car because the bulb was burnt out. Now what I took it to get it smoged again they said I wouldnt pass because when you start the car the light dosnt come on to show that is works. What elts could be the ploblem?
Monday, February 1st, 2010 AT 3:13 PM
BMRFIXIT
  • 19,053 POSTS
With key on engine off
you should have check engine light on
if not you have a problem
make sure that the bulb was replaced was in th correct place
if have check engine light on with key on and engine off
you should pass the light test
Monday, February 1st, 2010 AT 5:45 PM
