1996 Ford Escort CHECK ENGINE LIGHT
HYDROMAN1
  • 1996 FORD ESCORT
  • 4 CYL
  • FWD
  • 100,000 MILES
CAR RUNS GREAT AND LIGHT COMES ON AT ABOUT 35-40 MPH THE TRANS KINDA SKIPS A LITTLI TILL I GET TO 40 THEN RUNS GREAT AGIAN IF I RESET THE CODES IT STAUYS OFF TILL I GET AROUND THAT SPEED AGIAN.
Tuesday, January 29th, 2008 AT 6:35 PM
MASTERTECHTIM
  • 4,750 POSTS
Give me a hint. What code is it!
Tuesday, January 29th, 2008 AT 6:39 PM
HYDROMAN1
  • 5 POSTS
NO CODES YET WILL HAVE THEM READ TOMORROW
HAD TO WAIT TILL PAYDAY DUE TO MOVING HERE FROM ENGLAND USED UP ALL MY MONEY
Tuesday, January 29th, 2008 AT 7:02 PM
MASTERTECHTIM
  • 4,750 POSTS
If your near a autozone they will scan it for free.
Wednesday, January 30th, 2008 AT 5:00 PM
HYDROMAN1
  • 5 POSTS
I got codes read it came up with P0301 and P1443
Monday, February 4th, 2008 AT 5:41 AM
MASTERTECHTIM
  • 4,750 POSTS
Ok problem is not transmission your problem is ignition. Replace spark plugs and wires then get back to me with the good news.
Monday, February 4th, 2008 AT 2:50 PM
HYDROMAN1
  • 5 POSTS
Works great thanks for your help
Friday, February 8th, 2008 AT 8:50 AM
HYDROMAN1
  • 5 POSTS
Ok did ut agian with same codes but only when th overdrive gear kicks in
Sunday, February 10th, 2008 AT 7:36 AM
MASTERTECHTIM
  • 4,750 POSTS
Unplug you egr valves vacuum hoe and plug the vacuum hose. Drive vehicle and tell me if the problem is now gone.
Sunday, February 10th, 2008 AT 11:59 AM
