1996 Ford Escort abs
RSM227
Brakes problem
1996 Ford Escort 4 cyl Two Wheel Drive Manual
my front n/s brake keeps locking up , advised it may be a faulty sensor can i disconnect the sensor to see if it is, will it affect the braking system if i do
May 7, 2008 at 9:14 AM
BMRFIXIT
  • 19,053 POSTS
if the sensor is faulty then its not working
I don’t think by disconnecting it will do any thing
if you have an ABS issue a scanner will help
if the brake locking up check the caliper and hoses
May 7, 2008 at 1:06 PM
