1996 Ford Escort Lost Compression
SWRSPECTOR
I have two of these, one has 104,500mi and the other 94000mi. I bought the second one because the first died and now both are dead and died the same way. The cars were fine, I parked each one after driving and when I went to start the car, they would barely turn over and ran extremely rough before cutting off. I had a mechanic friend look at them and one (94K) has two cylinders without compression and the other (105K) has one without compression. The timing belts are fine on both and are aligned. What would cause these both to die the same way and what can I expect after pulling the heads off? I can't afford much so I may have to junk them but I have put a LOT of work and money in the 105K car.
Oct 29, 2007 at 5:29 AM
2CARPRO JACK
  • 11,533 POSTS
Older 1.9's lost the valve seats out of the head. Sometimes the head is repairable, but the piston usually takes a beating and needs to be replaced (comes from Ford with rings, rod and bearing)
Oct 29, 2007 at 5:38 AM
Suggested Repair
Older 1.9 engines commonly drop valve seats from the head. The head may be repairable, but the affected piston is usually damaged and should be replaced; Ford supplies the piston with rings, rod, and bearing.
Conversation Summary
The owner has two 1996 Ford Escort 1.9L cars that failed the same way after being parked: they barely cranked, ran extremely rough, and stalled. One has two cylinders without compression and the other has one; both timing belts are intact and aligned. The expert says older 1.9 engines drop valve seats, so the head may be repairable but the piston is usually damaged and needs replacement.
