HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Engine Cooling
Thermostat
1995 Ford Escort thermostat
PTEZ
MEMBER
1995 FORD ESCORT
4 CYL
FWD
AUTOMATIC
150,000 MILES
Where is the thermostat and how do I change it?
Wednesday, August 6th, 2008 AT 7:38 AM
BLACKOP555
MECHANIC
Bottom radiator hose, coolant will have to be drained, then lower radiator hose removed then the thermostat housing unbolted and removed.
Installation is opposite of removal, be sure to use new gasket.
Wednesday, August 6th, 2008 AT 9:27 AM
Please
login
or
register
to post a reply.
Related Thermostat Content
1995 Ford Escort Thermostat
1995 Ford Escort 4 Cyl Front Wheel Drive Automatic Location Of Thermostat Un Known
Asked by
matt2112
1995
FORD ESCORT
VIDEO
Thermostat Replacement Ford
Instructional repair video
GUIDE
Thermostat
The thermostat is located on the engine either at the inlet or outlet radiator hose connections and is part of the cooling system, this unit is designed to stop the flow of...
1995 Ford Escort
I Am Removing The Thermostat Housing To Replace Thermostat And One Of The Bolts Broke Off. I Tried To Remove With An Ez-out To No Avail....
Asked by
edeverstine
1 ANSWER
1995
FORD ESCORT
Checking Thermostat
1.9 Liter Engine. I Am Wondering How To Check Operation Of Thermostat On My Car. It Takes Too Long To Warm Up And Heat Is Only Sub-par...
Asked by
Carlpeck
2 IMAGES
1993
FORD ESCORT
2000 Ford Escort Thermostat
Air Conditioning Problem 2000 Ford Escort 4 Cyl Front Wheel Drive Automatic I Have A 2000 Ford Escort And The Thermostat Doesn't Work...
Asked by
blacck
2000
FORD ESCORT
2001 Ford Escort Thermostat Replacement
How Difficult A Task Is It To Replace The Thermostat In This Auto? Although The Engine Warms Up, The Heater Has Stopped Blowing Warm Air...
Asked by
RickPuccetti
1 ANSWER
2001
FORD ESCORT
VIEW MORE
How to Replace Thermostat
Thermostat Replacement Kia
