1995 Ford Escort starting problems
116,000 MILES • 4 CYL • FWD • MANUAL
RILES
Hi, Have a 95 ford escort with 1.9 engine, starter problem. When the key is turned to start there is a click in a relay on passenger side firewall,engine does not turn over.Yesterday had same problem but turned key several times and started. Today will not start. please help.
Jan 24, 2008 at 12:54 PM
2CARPRO JACK
  • 11,533 POSTS
If the engine isnt turning soundslike a bad starter. Verify by testing for 12 volts at the small wire on the starter when key is in crank position
Jan 25, 2008 at 7:21 AM
