1995 Ford Escort STARTING PROBLEM
150,000 MILES • 4 CYL • FWD • MANUAL
BLAIN4159
CAR STARTS FINE WHEN COLD, RUNS FINE, NO CHECK ENGIN LIGHT.
AFTER THE VEHICLE HAS RUN FOR ANY LENGTH OF TIME( AFTER IT HEATS UP) IT WILL NOT START FOR AT LEAST 15 MINUTES. THEN STARTS AT THE TURN OF THE KEY.
NEW FUEL PUMP
NEW EGR
NEW TPS
NEW BATTERY
NEW VACUUM LINES
NEW FUEL FILTER
NEW HEAD
IT DOES GO TO HIGH IDLE FREQENTLY.
ANY THOUGHTS
I AM THINKING A NEW COMPUTER
Mar 12, 2008 at 7:21 AM
MERLIN2021
  • 17,250 POSTS
Have you checked the Ignition module? 1.9 pic is first then 1.8 Distrib module...
https://images.2carpros.com/forum/automotive_pictures/62217_19IgnitionMod_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_18IgnMod_1.jpg
1.9 It's # 17 and 1.8 #13
Mar 12, 2008 at 7:32 AM
BLAIN4159
YES THAT WAS REPLACED LAST WEEK BECAUSE IT HAD A NOTICABLE CRACK. UNFORTUNATELY IT DIDN'T MAKE A DIFFERENCE.
Mar 12, 2008 at 7:36 AM
MERLIN2021
  • 17,250 POSTS
Check for a signal from the crank sensor...
Mar 12, 2008 at 8:08 AM
