1995 Ford Escort STARTING PROBLEM
BLAIN4159
  • 1995 FORD ESCORT
  • 4 CYL
  • FWD
  • MANUAL
  • 150,000 MILES
CAR STARTS FINE WHEN COLD, RUNS FINE, NO CHECK ENGIN LIGHT.
AFTER THE VEHICLE HAS RUN FOR ANY LENGTH OF TIME( AFTER IT HEATS UP) IT WILL NOT START FOR AT LEAST 15 MINUTES. THEN STARTS AT THE TURN OF THE KEY.
NEW FUEL PUMP
NEW EGR
NEW TPS
NEW BATTERY
NEW VACUUM LINES
NEW FUEL FILTER
NEW HEAD
IT DOES GO TO HIGH IDLE FREQENTLY.
ANY THOUGHTS
I AM THINKING A NEW COMPUTER
Wednesday, March 12th, 2008 AT 2:21 PM
MERLIN2021
  • 17,250 POSTS
Have you checked the Ignition module? 1.9 pic is first then 1.8 Distrib module...
https://www.2carpros.com/forum/automotive_pictures/62217_19IgnitionMod_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_18IgnMod_1.jpg
1.9 It's # 17 and 1.8 #13
Wednesday, March 12th, 2008 AT 2:32 PM
BLAIN4159
YES THAT WAS REPLACED LAST WEEK BECAUSE IT HAD A NOTICABLE CRACK. UNFORTUNATELY IT DIDN'T MAKE A DIFFERENCE.
Wednesday, March 12th, 2008 AT 2:36 PM
MERLIN2021
  • 17,250 POSTS
Check for a signal from the crank sensor.
Wednesday, March 12th, 2008 AT 3:08 PM
