1995 Ford Escort Power steering hoses
95,500 MILES • 4 CYL • FWD • AUTOMATIC
FLEETCOORDINATOR
  • 5 POSTS
My 17 year old was told by a mechanic the his power steering hoses are leaking. He had no leaks before they replaced his water pump. Now it leaves about a 4 inch dropping on the driveway. I am out of town and he wants to replace them himself. According to the parts house, it looks like there are 3 hoses? 2 with clamps, 1 with fittings. Should I let my son do it? Mechanic wants $125.00 for the hoses and $75.00 labor. Parts house list Fitting hose for $45.00 and other 2 for about $15.00 each.
Nov 11, 2008 at 7:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
That depends on how much experience he has with mechanics.
You may be saving $125, but if it is done wrong then you will be out a lot more than that for additional repairs.
Nov 11, 2008 at 7:36 AM
FLEETCOORDINATOR
  • 5 POSTS
[quote:94712004be="FleetCoordinator"]Steering problem
1995 Ford Escort 4 cyl Front Wheel Drive Automatic 95500 miles
My 17 year old was told by a mechanic the his power steering hoses are leaking. He had no leaks before the replaced his water pump. Now it leaves about a 4 inch dropping on the driveway. I am out of town and he wants to replace them himself. According to the parts house, it looks like there are 3 hoses? 2 with clamps, 1 with fittings. Should I let my son do it? Mechanic wants $125.00 for the hoses and $75.00 labor. Parts house list Fitting hose for $45.00 and other 2 for about $15.00 each. Should I let him replace the Power steering hoses, or check the hose clamps to see that they are tight.[/quote:94712004be]
Nov 11, 2008 at 7:55 AM
