1995 Ford Escort low fuel pressure
95,000 MILES • 4 CYL • FWD • AUTOMATIC
BBREEN42
while driving my vehicle it died (no warning) it turns over but will not start. There is spark. The fuel pump pressure with key on was between 2-20 psi. The pump was changed, still low fuel pressure. this vehicle is fuel injected. placed small amount of fuel in the carb, did not even attempt to start. I noticed there was a small amount of oil in the carb. I was concerned about ring problems (but this would not effect the fuel pressure??)
Jan 3, 2010 at 8:50 AM
BBREEN42
[quote:66bab942fa="bbreen42"]Engine Performance problem
1995 Ford Escort 4 cyl Front Wheel Drive Automatic 95000 miles
while driving my vehicle it died (no warning) it turns over but will not start. There is spark. The fuel pump pressure with key on was between 2-20 psi. The pump was changed, still low fuel pressure. this vehicle is fuel injected. placed small amount of fuel in the carb, did not even attempt to start. I noticed there was a small amount of oil in the carb. I was concerned about ring problems (but this would not effect the fuel pressure??)[/quote:66bab942fa]
Jan 3, 2010 at 8:52 AM
