fuel pump, pressure regulator, and filter changed, no pressure on the rail.
Oct 18, 2010 at 3:37 PM
✓Experienced Mechanic
Do you hear the fuel pump when you turn key to run? If so check the fuel pressure with a gauge-if not check the fuse, fuel pump relay and inertia switch. Let me know
